3 minutes ago, monyy47 said:
will I need to update the bios and will I need to buy another cpu just to update it
You probably will have to, if you do have to then AMD will ship you a free boot kit if you provide proof of purchase. Or you can ask the retailer to have he BIOS updated before they send it to you.
4 minutes ago, monyy47 said:
And does the mobo come with an I/O shield?
Every motherboard you buy new has a I/O shield, whether it's built in or a separate piece.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1106813-b45o-pro/#findComment-12911316
It's compatible on version F40 and higher of the BIOS.
Only way to know for sure what you're buying is good, is by seeing if there is a 'Ryzen 3000 ready' sticker on it.
Doesn't look like there is a way to update the BIOS without a usable chip inside it, you could look into the BIOS update kit AMD has through their RMA or ask a local store.
This motherboard has a built in IO shield, no seperate piece of metal.
https://linustechtips.com/topic/1106813-b45o-pro/#findComment-12911318
