Why would you want to do this?
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
3 minutes ago, MaTy said:
Because I need to use two Networks. One is for stability (gaming) and second for basics, like youtube videos, watching movies online..
Sounds overcomplicated. Just get one good network card or a better internet connection.
SPECS:
If the app itself gives you a choice of network then yes. If not then it wouldn't be a simple process to force it to.
For what reason do you want to? It's unlikely you're saturating your NIC's bandwidth. That and if everything is on the same network then this arrangement really wouldn't do anything for you.
Do you have 2 ISP connections?
As long as you're not running into a bandwith limit, you won't gain anything. Totally not worth the hassle.
2 minutes ago, MaTy said:
#1 I cant get better connection....
#2 Yes, I have two ISPs
What are your service plans on these ISPs?
@Senzelian My problem is that one provider has 60mbps down/up but its not stable... I can be only one on network and its still laggy. Thats why I want second network for my gaming, its only 10/5
In that case you might be able to limit certain applications to certain networks using the Windows Firewall.
@Windows7ge I dont realy know why are you asking...
ISP1: up?/down?
ISP2: up?/down?
Just now, MaTy said:
I just need one thing.... And thats how can I route my app to specific network... I have connected these two networks to my PC. I just want to have this setup only one my PC
ACL? Network Rules? Windows Firewall? You'd have to go an indirect route to force a particular application to use a separate network if the app doesn't support configuring this.
The easy/cheat way would be to either put it in a VM and tell it the 2nd network is the only available network or even setup a small second PC and connect it to the second ISP.
I am not an expert can you navigate me? @Senzelian
Nope, haven't done that myself. I know that the option exists in Windows 10 within the extended options of the Windows 10 Firewall.
Click around a little in the Firewall options and you should be able to find it or try to find the answer on Google.
@Windows7ge #1 60/15 not stable
#2 10/5 Stable
Have you talked to your ISP about the unstable connection? Did they just look at you and say it was normal?
1 minute ago, Senzelian said:
60/15
10/5
He had it already posted.
Ah, missed that.
@Windows7ge How can I do that? (ACL? Network Rules? Windows Firewall? You'd have to go an indirect route to force a particular application to use a separate network if the app doesn't support configuring this.)
I only have a basic understanding on how to configure ACL's on Cisco routers even then only on a client basis not application basis. Using Windows Firewall for this is something I've never done at all. You'll have to ask Google.
@Windows7ge They just cant repair that... Beacuse its about that, they are overloading (I dont know how to say that, I cant realy well english)
So they thinned out their bandwidth too much and now their infrastructure can't keep up with the demand. Can you outright switch ISPs? I'd want something more consistent and not cob-job my own network to compensate for their lack of reliability.
