Issues with new PC pls HELP
Go to solution Solved by StealthSlayer10,
SOLVED - Faulty ram slot :(
2 minutes ago, StealthSlayer10 said:
The PC just blackscreens and takes about 10 seconds to come back.
So I fucked this up recently too. Apparently it can happen if your using a really shitty cable so I would swap that out first. Also the PC is not rebooting right?
My life
  • 1 year later...
  • 2 months later...
