Build for 4K
Go to solution Solved by Herman Mcpootis,
1 hour ago, shinegull said:
Is it better to go for the 3700x over the 3600? I thought it was usually the case that i should save on the cpu for a better gpu if possible. Or is the 3700x better for reasons that i dont know?
you'll be fine with just the 3600, i picked the 3700x since there was still some money left over.
Im thinking of rebuilding my pc with a 3600 with a Asus Prime x570-Pro.
https://ca.pcpartpicker.com/list/pDbrx6
Ill be adding a wired and wireless nic as well
The monitor/tv i will be using is a Samsung Nu8000, 4K, up to 120 refresh rate( from what I understand)
Since im also using a 1070, will this build be enough to run games like ac odyssey, or ghost recon, as well as any other big game coming out in the next couple years at 4k?
Basically, ill be using this for gaming and media
Im hoping to run max settings if possible.
Im also doing a full custom loop for gpu and cpu to a 360 slim rad.
https://linustechtips.com/topic/1106560-build-for-4k/
Can the 1070 even run newer games at 4K high detail today? Last I checked I don't believe it could or it struggled at higher details at least especially if you're planning to push over 60FPS in those games with that TV/monitor.
Why are you spending over $1200 on SSDs?!?! Seriously, get a HDD for mass storage, you don't need everything on your computer to be NVMe/SSD based.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/1106560-build-for-4k/#findComment-12909349
I feel like this is just a troll post.
https://linustechtips.com/topic/1106560-build-for-4k/#findComment-12909380
Yah, I was skeptical at first but I had completely missed the SFF case at the start that will basically only fit a GPU, let alone a (useless) wired NIC and wireless NIC, or a full custom loop of any kind.
Prior Build Log/PC:
https://linustechtips.com/topic/1106560-build-for-4k/#findComment-12909391
4 hours ago, shinegull said:
Sorry, not a troll post. I do have the pc-o7 which can fit an atx mobo and atx psu. I have a custom loop with it at the moment. But i really am thinking of changing the motherboard and cpu
Your TV is maybe 1080p 120hz, or 4k 60hz.
You can run games at 1440p and use AMD's upscaling tech on NAVI to get closer to 4k visuals. So probably just get an RX 5700 pulse if it fits, buy a reference card otherwise.
Going past high settings in games really isn't worth it in general IMO.
Going to want an SFX power supply for a case that small/thin. Don't need those SSDs. Don't need more than 16GBs of RAM for gaming.
PCPartPicker Part List: https://ca.pcpartpicker.com/list/zxLH9G
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  ($448.50 @ Vuugo)
Motherboard: Gigabyte X570 I AORUS PRO WIFI Mini ITX AM4 Motherboard  ($291.99 @ PC-Canada)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 Memory  ($109.99 @ Newegg Canada)
Storage: Intel 660p Series 1.02 TB M.2-2280 NVME Solid State Drive  ($129.75 @ Vuugo)
Video Card: Sapphire Radeon RX 5700 8 GB PULSE Video Card  ($505.99 @ PC-Canada)
Case: Lian Li PC-O7S HTPC Case
Power Supply: Silverstone 500 W 80+ Gold Certified Fully Modular SFX Power Supply  ($130.94 @ Amazon Canada)
Total: $1617.16
Generated by PCPartPicker 2019-09-21 21:27 EDT-0400
There's also this Insane motherboard that's totally unnecessary.
https://www.asus.com/us/Motherboards/ROG-Crosshair-VIII-Impact/
https://linustechtips.com/topic/1106560-build-for-4k/#findComment-12909979
Motherboard: MSI B450 GAMING PRO CARBON AC ATX AM4 Motherboard  ($169.99 @ Canada Computers)
Memory: OLOy WarHawk RGB 16 GB (2 x 8 GB) DDR4-3000 Memory  ($91.99 @ Newegg Canada)
Storage: Crucial P1 1 TB M.2-2280 NVME Solid State Drive  ($129.21 @ shopRBC)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($67.99 @ Canada Computers)
Video Card: EVGA GeForce RTX 2080 Ti 11 GB Black Video Card  ($1379.99 @ Memory Express)
Power Supply: Corsair RMx (2018) 550 W 80+ Gold Certified Fully Modular ATX Power Supply  ($119.99 @ Corsair)
Total: $2407.66
Generated by PCPartPicker 2019-09-21 22:32 EDT-0400
https://linustechtips.com/topic/1106560-build-for-4k/#findComment-12910103
https://linustechtips.com/topic/1106560-build-for-4k/#findComment-12910522
