what device would I use to run internet from a modem with one ethernet port. I think I need a managed one, currently I have it run to my wifi router, and then it goes to 2 8-port unmanaged splitters(seem to be having issues). So what should I use to split the networking from the modem? (will have up to 3 instances of streaming at a time, most of the time on the ethernet network)
https://linustechtips.com/topic/1106322-help/
You wouldn't split the connection from your modem, it wouldn't work. The router performs some critical functions, so you'd need to split after the router.
What you'd need is a switch. Pretty much any Gigabit unmanaged switch will do you fine.
https://linustechtips.com/topic/1106322-help/#findComment-12907580
Unless you have purchased multiple IP addresses from your ISP, this wont work.
https://linustechtips.com/topic/1106322-help/#findComment-12908435
