Project Obsession: SFF Build ~ nkucz
nkucz
YES! when I purchase the GTX 770 I will definitely be grabbing a backplate, I think that should protect it right?
That'll protect from any issues, though I doubt there would be any issues anyways.  I think the short cable kit would help but if you sleeved it, it would be sexier ;)
i5 4670k| Asrock H81M-ITX| EVGA Nex 650g| WD Black 500Gb| H100 with SP120s| ASUS Matrix 7970 Platinum (just sold)| Patriot Venom 1600Mhz 8Gb| Bitfenix Prodigy. Build log in progress
Build Log here: http://linustechtips.com/main/topic/119926-yin-yang-prodigy-update-2-26-14/
Good! I actually just did some more cable management and it looks way better than it did before, even cleaner! I may sleeve them in the future but for the moment I'm focused on finishing everything else and perfect cable management. More pictures tomorrow when the sun is out and the lighting isn't horrible!
Intel i5 3570K || Gigabyte GeForce GTX 1070 8GB FE || 8GB Crucial Ballistix Sport 1600MHz || ASRock Z77 Pro 3 || WD Caviar Blue 1TB || Noctua NH-U12S || Creative Sound Blaster Audigy FX Sound Card || Fractal Define R4 || Gigabyte GC-WB867D-I REV 4.2 Wireless Network Card
ASUS VC239H Monitor || Corsair Strafe Cherry MX Red || Logitech G Pro || Philips SHP9500 w/ V-MODA BoomPro Mic || Reflex Lab Pro 36 Heavy Mouse Pad || Google Nexus 6P 128GB
Cables can always be better :) I'm currently doing mine too ;)
It's true! I always think of ideas while I'm on my computer or doing something else and test them out, it looks a lot cleaner now IMO. Good luck with your cables! Pesky things.
So my desk from Ikea arrived today...
It came damaged to, so now I have go through that whole process  :angry:
In other news here is some more cable management!
The wiring looks good. The desk doesn't :( .
looks awesome man, great work on that cable management
And then you realize your shoes are filled with peanut butter, what then?! >:L
no it doesn't! I'm very disappointed, called them last night and apparently someone will pick it up and drop off a new one at the same time.
thanks very much! appreciate it  :D
Cables look great! If you get a back plate, It would be cool White ;)
Nice work! ;)
Best regards!
Thanks! Your Node 304 isn't to shabby  ;)
Thank you! You mean paint the back plate white?
Yes the one in my profile picture is painted (my backplate)
