Looking for some help diagnosing the issue with my current main monitor, it is a 1440/144hz so would ideally like to try and fix it.
Images show the vision of the monitor, occasionally it will flicker bits of the screen around a bit.
Things I have tried
Different cables and connector types
Resetting the Monitor
Connecting to different System
Checking for Software Issues (This still happens in BIOS, which I think would mean its not a software fault)
Other monitors work fine using the same cables and inputs. Looking for any info anyone might have20190916_143147.thumb.jpg.e51977aec0f24076f9e17db09fbc0661.jpg
https://linustechtips.com/topic/1104905-display-pixels-double-vision-and-broken/
Things I have tried
Just to confirm, when connected to a totally different system the issue is still present, correct?
If so then it's most likely the monitor is bad.
Be sure to QUOTE or TAG me in your reply so I see it!
CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15
Yeah, problem is present on every configuration I have tried
Sounds like the monitor is faulty then, unfortunately.
