Posted September 13, 2019 As the title states, i can't get the bluetooth to work on my gigabyte gc-wb1733d-i. The card provides wi-fi over PCIE (which works) and bluetooth over a USB connection directly on the mobo on a USB-F port, i tried everything, changing pcie port, changing usb-f port, changing card alltoghether but nothing works, and what makes me even angrier is that there's a USB passthrough on the card (through the same usb cable used for BT) which works. I tried installing intel and gigabyte official drivers and looking in device manager for legacy devices, nothing worked. My setup is as follows: ASUS prime X570 AMD Ryzen 3600X GTX 970 Reference Any help would be greatly appreciated. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 13, 2019 Author SOLVED I was connecting to a USB-F on the mobo that had only one connection while the card required 2. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 15, 2019 hi mate, how did you solve this - identical setup and issue here. i plugged the usb 5x2 head into usb11 port, also tried usb910 port. no luck. cant get it detected in device manager. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
