MSI RX 470 Armor OC DVI-D to VGA and HDMI to VGA Active adapters not working
Hello.
I have an RX 470 armor oc 4gb. It has 1 HDMI port, 1 DVI-D Dual link port, 2x display port. Problem is I have an HDTV at 1080p 60hz. When I use an HDMI cable, the output is too sharp and seems like the problem is with the tv so I am using VGA. I bought 2 ACTIVE adapters, 1 DVD-D DL to VGA and 1 HDMI to VGA however, none of them works. If I use HDMI cable there is output on Monitor. I plan to buy a DP Port to VGA Active adapter however, I am not sure if it will work as well.
Any advise?
Just use HDMI. There is no reason to use VGA
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
Hi. Thanks for the reply,
If I use HDMI cable, the display is so ugly and over sharpened, colors are washed out. this is a problem with the TV itself EDID-related issue. So I have no choice but to use VGA Input.
Have you tried adjusting settings?
I did. I tried all settings in the tv. I also tried using different gpus with HDMI on my hdtv and they are the same. Only option is to use VGA Adapter with an active adapter. problem is my rx 470 doesn't support them.
I have a gtx 750 from msi as well and its ports are vga, hdmi and Dual-link DVI-D. this is the same with my rx 470 but the dvi d adapter works on gtx 750 but not on rx 470.
