Weird Idle Temps on Ryzen 3600X
Go to solution Solved by 5x5,
Disregard those readings. Only Ryzen Master can track Ryzen CPUs in idle
Hey, I got weird idle temps on my Ryzen 3600X. They are jumping between 40C and 50C (sometimes up to 59C). Temps are immediately jumping up after reaching about 40C. I'm using the MSI B450 TOMAHAWK MAX with the newest BIOS [7C02v331(Beta version)]. The same also happend on BIOS [7C02v321(Beta version)]. Running the CPU stock or with PBO produces same results. I'm also using the Ryzen Balanced Windows Power Plan. I'm cooling with the NZXT Kraken X62 280mm. Voltages for the cores are between 1.425V - 1.45V which is stock for this board. Core clocks are sitting at 4.275 GHz 95% of the time with PBO.
Does anyone have an idea what's causing this?
Thanks in advance
https://linustechtips.com/topic/1103771-weird-idle-temps-on-ryzen-3600x/
