1 minute ago, Saksham said:
Probably just the snapdragon vs exynos processors.
https://linustechtips.com/topic/1103546-note10/#findComment-12885044
no. they are both SD855
It's the color then looks like.
But if gaming is your focus, I'd go for a 90hz phone probably.
https://linustechtips.com/topic/1103546-note10/#findComment-12885058
I'd probably go for the Asus phone if you're gaming.
Or one of the Chinese gaming phones. They're rather solid as well.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1103546-note10/#findComment-12885092
17 minutes ago, Saksham said:
im not gaming. i dont need high refresh
Then...why did you post in the mobile gaming subforum?
Also the high refresh isn't just for gaming.
https://linustechtips.com/topic/1103546-note10/#findComment-12885666
