Looking for 144hz monitor
xReqt
Hi,
I have a budget of 180 pounds (No more then that) and im looking to get a good looking 144Hz monitor 24" or more and 1ms refresh rate. Must be able to purchase on Amazon UK
If you link something please evaluate why its good as i'll never know as im not a wiz with monitors.
Anything you link is so much appreciated!
Cheers
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
16GB DDR4 Crucial ram (2133mhz)
Prime Z370-A Motherboard
Gamemax Falcon (White)
Peripherals
Logitech G305
Corsair Strafe MX RED
Blue Yeti /w arm
JVC (Headphones)
https://uk.pcpartpicker.com/product/HBRzK8/aoc-c24g1-240-1920x1080-144-hz-monitor-c24g1
cheapest monitor with your desired specs, and is curved. Although I hear some horror stories about AOC monitors so
https://uk.pcpartpicker.com/product/4Hc48d/dell-s2419hgf-240-1920x1080-144-hz-monitor-s2419hgf
this one has that nice dell stand, might be more suitable depending on your desk layout.
Primary PC:
I used to have two of this monitor, one of the best monitors I've ever owned. Good color, brightness, no bad light bleeding, and 144hz + 1ms response times and can also be overclocked to a higher refresh rate if needed. It's not too much over your budget because it is on sale and is only barely outside your budget, if you can afford the extra money this is one that I would highly recommend you get especially at the price.
https://www.amazon.co.uk/ASUS-VG248QE-Widescreen-Multimedia-80000000/dp/B00B19T7QC/ref=sr_1_5?keywords=144hz+monitor&qid=1568229396&s=gateway&sr=8-5
This is another monitor I have used which is within your budget however the ASUS is better in my opinion, I prefer the colors and brightness of the ASUS over this one.
https://www.amazon.co.uk/BenQ-XL2411P-Sports-Adjustable-eQualizer/dp/B075JGL4WV/ref=sr_1_3?keywords=144hz+monitor&qid=1568229603&s=gateway&sr=8-3
This is another in your budget but AOC has had some majors issues and a friend of mine who had this monitor received two units with dead pixels before they sent him one that didn't.
https://www.amazon.co.uk/AOC-C24G1-23-6-Inch-Curved-Monitor/dp/B07DTN4BM8/ref=sr_1_6?keywords=144hz+monitor&qid=1568229603&s=gateway&sr=8-6
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z690 Aorus Elite AX DDR4 | GPU - ASUS TUF Gaming OC RTX 4090 RAM - Corsair Vengeance Pro RGB 64GB 3600mhz | AIO - H150i Pro XT | PSU - Corsair RM1000X | Case - Phanteks P500A Digital - White | Storage - Samsung 970 Pro M.2 NVME SSD 512GB / Sabrent Rocket 1TB Nvme / Samsung 860 Evo Pro 500GB / Samsung 970 EVO Plus 2tb Nvme / Samsung 870 QVO 4TB  |
TV Streaming PC: Intel Nuc CPU - i7 8th Gen | RAM - 16GB DDR4 2666mhz | Storage - 256GB WD Black M.2 NVME SSD |
Phone: Samsung Galaxy Z Fold 4 - Phantom Black 512GB |
@Fasauceome @SpookyCitrus Thanks for all the help, I decided to go with the Benq XL2411P its a little on the ugly side but I read some into it and it offers more then enough to think its under priced. Thanks again : )
PC SPECS
I7-8700 (non K)
GTX 1070
Corsair H100x AIO
Peripherals
Logitech G305
Blue Yeti /w arm
JVC (Headphones)
