CPU - 4770k (not overclocked/overvolted)
Cooler - be quiet Dark Rock 2 (a fairly new addition)
Temperatures being monitored with HWMonitor and AISuite
At idle the temperatures between AISuite and HWMonitor line up to within a degree or two of each other (34 in AISuite and 36 on the hottest core in HWMonitor) but when I run Prime95 Blend (temperatures were taken about 10-15 minutes after starting the test) the difference becomes much larger.
AISuite - 54°
HWMonitor - 66°
Im not familiar enough to know if this large of a difference is normal (they just measure temperatures differently) or if user error is at fault.
https://linustechtips.com/topic/110319-cpu-temperature-discrepancy/
They might be different. One measuring the core, and the other the socket.
Wanna hang out with me and people like @Theslsamg, @ Ssoele, @BENTHEREN, @Lanoi, @Whiskers, @_ASSASSIN_, @Looney, @WunderWuffle, and @nsyedhasan. Well.... Check out: http://linustechtips.com/main/topic/48484-unofficial-linustechtips-teamschnitzel-server-teamspeak/
