Hey LTT community. I recently bought an asus prime x470 pro motherboard and a ryzen 5 2600. I found out that my system is highly gpu bottlenecked and Im planning on getting a new gpu. I was considering a msi radeon rx570 8gb for 150euros. I have read and seen that works pretty good with ryzen 5 2nd gen. My budget is around 150 euros (i consider buying used). I would like suggesting me a gpu with the lowest possible bottlenecking. If you know, tell me if the rx570 8gb may bottleneck my system again.
https://linustechtips.com/topic/1102553-bottlenecking-i-need-help/
Hilarious !!!
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
For 150 euros the 570 is the best you'll get, unless you get an RX 580 used. At this budget a bottleneck should not be your concern
Primary PC:
PSU tier list
How many watts do I need?
