So I'm running this i9 9900k at 5mhz at 1.3 volts with an AVX offset of 2. On OCCT stress im getting temps around 70-80 which is fine and also the AVX offset is being used on that so I'm at about 4.8mhz.
All of that is fine.
The problem I'm running into is on Real bench. On real bench my CPU is running from 85-95 while my 2080ti is in the 60's.
Also my RAM is Corsair Dominator Plat RGB 16gb running at XMP 3200. (default)
My cooler is a 240mm Corsair H100i pro.
Any thoughts?
https://linustechtips.com/topic/1102484-i9-9900k-temps/
Any thoughts?
Not unusual. Real bench is a "proper" system stability test.
https://linustechtips.com/topic/1102484-i9-9900k-temps/#findComment-12875754
2 minutes ago, honeymixes said:
So I should keep it as is? Idk seeing my CPU go that high scares me. But it's a heavy test I guess.
You'll not hit those temps under a regular load. It'll be alright.
https://linustechtips.com/topic/1102484-i9-9900k-temps/#findComment-12875774
those temps are actually on the lower side for real bench and 100i on 1.3v, you good.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/1102484-i9-9900k-temps/#findComment-12875778
Well  1.30v is good.  I see people taking it to 1.40 and some 1.50v and that is insane and no good.  Try ti never go above 1.32v.  Also like peeps up top explained you will never hit Prime95 or stress test synthetic benchmarks and what not.  At least 10 to 12c more from Prime95 which is synthetic like I said, in the real world you will have good temps.  Also try Aida64 stability test and see where your CPU temps are at.  They should be 70's c worst case 80c and what not.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1102484-i9-9900k-temps/#findComment-12875808
