750 watts is a ton, you'd only need a 550 watt PSU for a gaming PC, but there are reasons not to get a Seasonic Focus unit.
Consider one of these
https://pcpartpicker.com/product/zhHRsY/cooler-master-mwe-gold-550-w-80-gold-certified-atx-power-supply-mpy-5501-acaag-us
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1102352-is-this-enough-power/#findComment-12874677
6 minutes ago, dreamcast4599 said:
thanks wasnt sure
The CPU needs 65-70 at stock with 100-110 overclocked. GPU uses 200W or so. 50W for everything else and you under 400W. You can run that system on any decent 450W PSU. 750W is enough for your system X2 and is utterly pointless overkill. Get a Corsair.RMx 550W or Be Quiet Straight Power 11 600W
https://linustechtips.com/topic/1102352-is-this-enough-power/#findComment-12874680
