So I bought a budget case, some generic Chinese brand Sama, not sure of the model. But I never liked the plexi window or the lack of venting on the front. Decided to draw something up in Fusion 360 and send it out to get fabricated. $20 and a day later, I had my two panels. I need to do a better job with the paint, butti think it turned out OK.
https://linustechtips.com/topic/1101144-simple-panel-replacement-sama-case/
1 hour ago, TempestCatto said:
The front panel looks pretty neat.
Where do you get something like this done at?
Thanks, i live in China so I used taobao.com. There are shops to make anything if you can give them a design file. I've had so much stuff made since moving here at a fraction of the cost as Canada.
