USB device not recognized.
Solved by GlaZe08,
31 minutes ago, Windows7ge said:What if you tried testing every port with a thumb drive? (Whichever one it doesn't register in is the problem) I'm guessing a USB controller is malfunctioning.
Oh sorry. I thought i send a message earlier but i guess not.
I missed one small cable when unplugging the USB hub, but the problem seems to have gone away after i removed that last cable. So its probably something with that USB hub.
I never use it though so having it disconnected isn't an issue and i will probably be getting a new PC in the near future anyways.
Thank you so much for the quick replies really appreciate the help! ![]()
