Reset Mobile without logging in
Solved by TJ10,
On 8/31/2019 at 2:59 PM, LogicalDrm said:-> Moved to Phones and Tablets
You should be able to reset it without SIM. Just enter recovery mode. You may need to Google how-to.
I have the same phone and it is impossible to remove the FRP lock without the previous screen protection used on the phone or without using the previous google account on the phone. You need to ask your father to enter his account info and then the FRP will go away.
After that you can add your own Google Account.
