While watching videos about some budget gaming pc it made me want to get one, so while browsing Facebook marketplace I came across a 25$ Antec 1200 case with the fan. So here's my question, as I'm buying a case from 2008 and not financially available to get some new parts, I was wondering what are the best parts for the computer in the 2008-2010 budget range. I already have a monitor, keyboard,mouse, and hdd with windows 8(which I can soon upgrade to a sdd hopefully. Sorry if I posted this in the wrong place. Thanks for helping
https://linustechtips.com/topic/1099803-first-pc/
just buy the best you can get instead of just looking at parts from 2008-2010?
https://linustechtips.com/topic/1099803-first-pc/#findComment-12854551
5 minutes ago, LostCalendar said:
What's your budget/country?
https://linustechtips.com/topic/1099803-first-pc/#findComment-12854554
As others have stated the used market really depends on where your located.
But I don't recommend a 2008-2010 computer at all. If your in the US, start looking around for computers used in business like the dell optiplex, you can get them on ebay/amazon etc.. for pretty cheap. Under $100 many of the times.
https://linustechtips.com/topic/1099803-first-pc/#findComment-12854578
