A few changes.
You want an aftermarket version of the 5700 XT as the blower type run hotter and louder. Not sure what the best one is as not a lot have prices anyway. Something like the Sapphire Pulse or the Powercolor Red Devil etc if you can wait for stock. You also have XFX who are usually fine for AMD.
Slightly cheaper ram and a B450 Tomahawk (See if you can get the MAX version though). The board has bios flashback anyway. Also dropped down to a 650W psu which is more than enough.
https://linustechtips.com/topic/1099633-need-help-with-a-build/#findComment-12853209
It looks decent. Remember that X470 board will need a Bios update to accept Ryzen 3000 CPU. Otherwise your PC won't even post. Also get an aftermarket GPU. Blower coolers are bad.
Edited by PopsicleHustler
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
https://linustechtips.com/topic/1099633-need-help-with-a-build/#findComment-12853213
I'll recommend something like this instead...
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($193.99 @ SuperBiiz)
Motherboard: MSI B450-A PRO ATX AM4 Motherboard  ($84.89 @ OutletPC) Supports BIOS flashback.
Memory: OLOy WarHawk RGB 16 GB (2 x 8 GB) DDR4-3200 Memory  ($66.99 @ Newegg)
Storage: Intel 660p Series 1.02 TB M.2-2280 NVME Solid State Drive  ($94.99 @ Amazon)
Video Card: MSI Radeon RX 5700 XT 8 GB MECH OC Video Card  ($424.99 @ Newegg)
Case: Fractal Design Meshify C ATX Mid Tower Case  ($88.99 @ Newegg Business)
Power Supply: BitFenix Formula Gold 550 W 80+ Gold Certified ATX Power Supply  ($69.99)
Total: $1024.83
Generated by PCPartPicker 2019-08-30 13:03 EDT-0400
PSU link - https://www.newegg.com/bitfenix-formula-gold-series-bp-fm550ulag-7r-550w/p/N82E16817376010
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1099633-need-help-with-a-build/#findComment-12853224
15 minutes ago, lee32uk said:
A few changes.
Wont x470 be better for future upgrades?
also, What would i have to do If i wanted to try overclocking? I mean What changes would i have to do.
https://linustechtips.com/topic/1099633-need-help-with-a-build/#findComment-12853250
Not really a lot of difference between B450 and X470.
The 3000 series don't really overclock that great. The cpu will boost itself though, so you can just let it do it's own thing.
https://linustechtips.com/topic/1099633-need-help-with-a-build/#findComment-12853309
What about ram OC? Because i read somewhere that i can get 3200 memory above 3600 with OCing
https://linustechtips.com/topic/1099633-need-help-with-a-build/#findComment-12853489
Yeah you can overclock ram but no guarantee how far it will overclock. You can use Ryzen dram calculator and thaiphoon burner though if you want to try it.
https://linustechtips.com/topic/1099633-need-help-with-a-build/#findComment-12853540
3 hours ago, lee32uk said:
A few changes.
Dont tell him to get b450 without telling him to update the bios...
https://linustechtips.com/topic/1099633-need-help-with-a-build/#findComment-12853705
Why would I need to tell him to update the bios ? The MAX board should work out of the box, which is why I told him to get that version. Not difficult anyway with bios flashback.
https://linustechtips.com/topic/1099633-need-help-with-a-build/#findComment-12853747
i know im picky, but is there any good b450 board thats white? i want to keep the pc theme as b&w
https://linustechtips.com/topic/1099633-need-help-with-a-build/#findComment-12853758
I think the one in your initial spec is the only one that springs to mind. You have a couple of boards that are silver like the ASRock Steel Legend and the MSI B450 Mortar Titanium. I know that MSI did a couple of White B350 boards like the Tomahawk Arctic and Krait but they are not sold anymore. You could always ask the retailer if they could update the bios on the Asus X470, or request a boot kit from AMD etc if you like that board.
https://linustechtips.com/topic/1099633-need-help-with-a-build/#findComment-12853865
