Can you post a picture of the connector? or tell us the exact model of cooler master RGB controller?
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/1099531-rgb-fans-help/#findComment-12852469
AFAIK you don't connect that to mobo. You use USB connector. And connect power directly from PSU. If you mean for fan speeds, then any 4pin PWM header will do. Could you link to controller you have?
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1099531-rgb-fans-help/#findComment-12853006
https://www.coolermaster.com/catalog/coolers/rgb-accessories/wired-rgb-controller-c10l/
i know it's not much but if it works i'm okay with it..
https://linustechtips.com/topic/1099531-rgb-fans-help/#findComment-12854051
Yep, you don't connect that to mobo. Only with USB. Fans you still need to power from mobo fan headers as that controller is for rgb only.
https://linustechtips.com/topic/1099531-rgb-fans-help/#findComment-12854605
44 minutes ago, sheep_ said:
okay thanks! so those 4-pin pwm connectors that say "usb"?
No...? The controller has 4pin rgb connectors. And micro-USB. If you want to sync with mobos rgb, then you can connect it to generic rgb header. This is mainly guessing as I can't get manual to verify.
https://linustechtips.com/topic/1099531-rgb-fans-help/#findComment-12854859
my motherboard doesnt have an rgb header..
https://linustechtips.com/topic/1099531-rgb-fans-help/#findComment-12856452
That part is optional. The controller is meant for that. You can connect to mobo for sync, but it's not necessary. It has buttons for controls.
https://linustechtips.com/topic/1099531-rgb-fans-help/#findComment-12856982
2 hours ago, sheep_ said:
so how do i connect the controller correctly?
SATA power from PSU and then RGB from fans to hub. That is pretty much all I can say as I don't have access to manual.
https://linustechtips.com/topic/1099531-rgb-fans-help/#findComment-12862419
