Best language for backend web dev
Solved by bowrilla,
3 hours ago, wasab said:Is one faster to code and deploy compare to the other? I heard from my school alumni that projects in this class is easily a 30 hour a week time sink
I really want to pick something that's gonna make my life easier.
Not really a big difference once you wrapped your head around it. Javascript differs heavily from version to version in some parts (callback of hell vs await vs async). Python uses indentation as syntax. Go with the language you like the best. Though I have to say - if there'll be a frontend course coming at you in the foreseeable future I'd definitely go with node.js/javascript since you just stick with one language which is a plus if you plan to get better at it.
