Can you be more specific to your issue, to your full specs list, what game, if you checked the usage of your hardware during game and so on?
There's really no way to help you with this little and vague information provided.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1099214-cpu-bottle-neck-help/#findComment-12849826
Thank you, for your support. these are all the specs I can find.
Cpu: intel core i5 9600k @3.70Ghz 3.70Hz cooling: Deepcool Neptwin v2 MOBO: msi z390-A pro Ram: 16Gb Gpu: GTX1060 6Gb PSU: EVGA 500B Boot? (do you mean operating system?): windows 64bit Storage: seagate 1Tb
https://linustechtips.com/topic/1099214-cpu-bottle-neck-help/#findComment-12849875
Download MSi Afterburner and go play a game for 10 minutes then take a screenshot of the CPU and GPU usage and temperatures.
Also download CPU-z and take SS of all the tabs for us.
The i5 9600K is not going to bottleneck a GTX 1060 you should be getting the most out of your GPU in games, so you're running at some sort of issue... it could be because you're running off a HDD alone for both OS and Game it could be a form of bottleneck, if the memory is clocked to 2133mhz it's also going to hinder performance.
However given you play a little and performance takes a while to drop down, it is very possible you're thermal throttling somewhere and might have to remount your coolers and such.
Personal Desktop":
https://linustechtips.com/topic/1099214-cpu-bottle-neck-help/#findComment-12849888
I got something like this.
08:02:08 Connected to MSI Afterburner control interface v2.3
08:02:12 GPU1 : VEN_10DE&DEV_1C03&SUBSYS_371A1458&REV_A1&BUS_1&DEV_0&FN_0
08:02:12   Memory clock    +0MHz
08:02:12   Overvoltage    0  %
08:02:12   Power limit    100%
08:02:12   Thermal limit    83 °C
08:02:12   Fan speed 1    Auto
08:02:12 Start scanning, please wait a few minutes
08:02:14 Scanning point 1 of 4
08:04:12 Scanning point 2 of 4
08:06:52 Scanning point 3 of 4
08:10:14 Scanning point 4 of 4
08:13:06 Scan succeeded, average overclock is 82MHz
08:13:06 Dominant limiters
08:13:06   No load
08:13:06 Overclocked curve exported to MSI Afterburner
https://linustechtips.com/topic/1099214-cpu-bottle-neck-help/#findComment-12850021
