There aren't ITX cases that support mATX, they'd be mATX then
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1098999-best-itxmatx-case/#findComment-12848078
3 hours ago, Hendricks3 said:
So are there any mATX thats similar to the node 202?
Silverstone makes a list of HTPC cases.
Thin ones for no dGPU or low profile GPU systems:
https://pcpartpicker.com/product/bWR48d/silverstone-case-ml03b
https://pcpartpicker.com/product/fsw323/silverstone-case-ml04b
Larger ones that support full size GPU's
https://pcpartpicker.com/product/RGZQzy/silverstone-case-gd06b
https://pcpartpicker.com/product/mKw323/silverstone-case-sstgd05busb30
https://linustechtips.com/topic/1098999-best-itxmatx-case/#findComment-12848543
