Hey guys, I was attaching the Artic Xtreme IV to my Zotac Twin Fan 2080 Ti, but noticed that the gpu die wasn't making contact with the cooler. It seems like the long screw's nut is blocking the gpu die from making contact. I removed the washers to see if I could get it to do so, but the nuts are still blocking contact. Any help would be appreciated.
https://linustechtips.com/topic/1098958-artic-xtreme-iv-help/
Erm, could just use the cooler that came with the card...
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
https://linustechtips.com/topic/1098958-artic-xtreme-iv-help/#findComment-12847824
3 hours ago, octojay_766 said:
I was but I was getting to like 85C or more even with an agressive fan curve. I was trying to reduce noise and heat in my system with this cooler
sure, but i also imagine it will run even hotter with a cooler that doesn't touch the die /s does Arctics' website list support for the 2080Ti? it could also be because it is an AIB model
https://linustechtips.com/topic/1098958-artic-xtreme-iv-help/#findComment-12847902
