Help for build
Go to solution Solved by Wohaaa,
16 minutes ago, Slottr said:
None, you shouldn't be looking at a 9600k. AMD's equivalent price range is significantly better.
Not to mention, what is this system for?
11 minutes ago, 5x5 said:
Don't buy a 9600K - a Ryzen 5 3600 is faster, cheaper, uses less power, runs cooler and doesn't suffer from the severe security vulnerabilities in Intel CPUs
16 minutes ago, Sychic said:
why are you buying 32gb of ram but only a 1660ti? you could go down to 16gb and get a better gpu first. Also motherboard mostly just depends on what you want in it. Also what your budget is
Could be that he already has the parts.
I'd say get an MSI Z390-A PRO or ASUS PRIME Z390-A as they're both Z390 and they seem to be lower cost than most other Z390 boards. Though I'm not really experienced with motherboards and would suggest someone who knows their stuff give suggestions.
https://linustechtips.com/topic/1098876-help-for-build/#findComment-12847136
It is said that an Italian dies every time Spaghetti is broken.
That's why I break mine twice.
https://linustechtips.com/topic/1098876-help-for-build/#findComment-12847181
