mouse help
Solved by PCGuy_5960,
16 hours ago, harvey likes intel said:i have small hands ( im a kid ) and use the g502 but the mouse is feeling heavy does anyone have suggestions? if so thanks im also a palm grip if that changes anything
I'd recommend the G305 (it's not ideal for palm grip, but if you have small hands, it should be fine), the G403 and the Model O-.
If you get the G305, I'd recommend using a lithium battery. It lasts longer and makes the mouse only 89g or something.
