Recently built a PC. Managed to get it working fora good week. All of a sudden this evening, it is not posting at all.
I have tried clearing CMOS but to no avail. Try resitting RAM 1/2 sticks but nothing. Don't really know what else to do.
My specs are as follows:
CPU: Ryzen 3700x
Motherboard: gigabyte x570 aorus pro
Ram:Corsair vengeance 3600mhz CMK16GX4M2D3600C18
PSU: evga G2 750w
GPU: Nvidia 2080 super
https://linustechtips.com/topic/1098640-newly-built-pc-wont-post/
Likely, since the memory did work for a while. Also check the board, whether there are burns near the memory VRM which is on the right of the dimm slots near the top right corner
Desktop benching:
6 minutes ago, Quagral said:
Everything spins, including lights but nothing on the monitor. Dram led is lit up. Is my RAM busted??
Yeah, sounds like it. If you can get your hands on some known good RAM to test, you could see if it is your mobo or RAM. But if you just got it, you'll probably be able to RMA whatever it is instead of paying for a new one.
if nothing is coming up on the monitor, then no. There's a small chance it could be your GPU  that is the problem, and the PC actually is posting, you just can't see it. If your monitor isn't being woken up by your PC, try different ports/cables for your display and see if that helps. Other than that, you'd probably be best off swapping hardware and using process of elimination.
14 minutes ago, Quagral said:
Supposedly the ram that I have is not compatible with Ryzen but it is not Ryzen rated. Is this a likely problem??
DDR4 is still DDR4, the XMP profile might not run but it will run 2133MHz which is what boards do by default with these sticks.
Desktop benching:
4 hours ago, manicottimuffin said:
It’s not likely at all that they’d both me bad... have you tried different RAM slots? And different ram in each slot? I’d also try reseating the CPU. If neither of those work, it could be your board.
I'll give reseating the CPU a try. Just unusual it worked flawlessly for a week then all of a sudden it's like this
Yeah, that’s pretty crazy. That’s the X factor when building your own, stuff like this happens from time to time. Did reseating the cpu work?
Nothing still..now I'm going crazy. Don't know if it's mobo or ram. Don't know if I should rma both..or.maybe CPU. I'm going crazy
Can you take it to a local pc shop? Or maybe go to an electronics store and buy ram/cpu to test and then return them to the store?
19 minutes ago, Quagral said:
Going to RMA the ram, kinda disencouraged with going back to Corsair. Since it's under 30 days I can get a refund. Gonna get something else instead. Hopefully I made the right call, and hopefully it really is ram that is busted
Yeah, I mean Corsair is pretty reputable but it could just be a crazy coincidence. If the new sticks don’t work I’d say mobo next
Yeah, exactly my thought. At least I don't have to buy an entirely new system, and I could just RMA and stuff. Just such a hassle though
Did you try with ONE stick of RAM at a time?
If having only 1 stick in the system doesn't work, that THAT one out, and put the second one in.
You need to find out it if:
  • Is it RAM or motherboard that died?
  • If it is RAM, it is 1 stick, or both sticks dead?
No point RMA'ing the RAM if the memory slot on the motherboard roasted itself...
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
