I know we have 2 forums for cooling but this question spans over the two and did not want to duplicate my question.
For these CPUs in the last 3 years or so, do they need water cooling or is air cooling ok? For my i7 extreme I have had for 6 years, it's been only air cooling... I dont do overclocking and do have heavy loads on it.
Seems water cooling is only to show off RGB stuff...??
In any event... air or water? And how easy or difficult is water cooling?
What about when transporting a desktop system? Remove the water or can I just move it as it is when travelling?
Thank you for your clarifications! ?
https://linustechtips.com/topic/1098012-intel-cpu-cooling/
u could choose a kind of half way choice and go for an AIO.
Really easy to fit even for me whos had a minor stroke and has problems with right hand and arm.
MSI MAG X670E TOMAHAWK WIFI Motherboard, AMD Ryzen 9 7900X3D Desk-top Processor (12-core/24-thread, 140MB cache, up to 5.6 GHz max boost), CORSAIR VENGEANCE DDR5 RAM 32GB (2x16GB) 6000MHz CL30 AMD EXPO iCUE Compatible Computer Memory, Samsung 990 PRO NVMe M.2 SSD, 2 TB, PCIe 4.0, 7,450 MB/s read, 6,900 MB/s write, Internal SSD, 2 x Seagate BarraCuda 4 TB Internal Hard Drive HDD – 3.5 Inch SATA 6 Gb/s 5400 RPM 256 MB Cache for Computer Desktop PC Laptop (ST4000DM004), MSI MPG A1000G PCIE5 Power Supply Unit, UK Plug - 1000W, 80 Plus Gold Certified, Fully Modular ATX 3.0, PCIe 5.0 GPU, XILENCE XC982 LQ240PRO AIO COOLER, XFX Speedster MERC 310 AMD Radeon RX 7900 XT 20GB 1 x AOC CU34G2XE & 1 x Samsung U32J59XUQ 3840 x 2160 4K, 1 x Samsung Evo 970 Evo Plus NVME PCI-E 1TB, 1 x Samsung Evo 850 250GB, 1 X Sandisk Ultra II SSD 240GB + 2 X 4TB Seagate Barracuda SATA III,  MZHOU 7 Ports PCIe USB 3.0 Card,  2 x UGREEN Hard Drive Enclosure 3.5 inch External SATA Disk Caddy Reader USB 3.0 2.5 3.5 HDD SSD 16TB UASP Case Dock Station With 12V 2A Power Adapter For Windows with 6TB Seagate Barracuda SATA III, Fractal Design Pop XL Case + 4 Fractal Design 140mm Case Fans, Logitech MX Vertical & MX Ergo Trackball Mouse using same USB unifying device, Microsoft Ergonomic Keyboard, Windows 11 Pro x64 Retail, 6TB Seagate USB 3.0 Backup Plus Hub, Blue Yeti Microphone, Logitech C922 Pro HD,  Logitech C920 Pro HD, Bit Defender Total Security 2021.
Second PC (Cyclops) - MSI 990FXA Gaming, AMD FX 8370 4Ghz, Corsair 16GB Vengeance Red 9-9-9-24 1600Mhz, Arctic Cooling Freezer 13, Asus Strix 1050TI 4GB, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 1 x Samsung Evo 850 250GB, 2 X Seagate Barracuda 2TB, 1 X WD Black 2TB, 1 x ASUS 16x DVDRW, X-Case Eagle III Case, 3 X Corsair AF 120 Case Fans, EVGA 850 G2 80+ Gold + PSU, Logitech MX Master Mouse, Corsair K30 Keyboard, Logitech C920 Webcam, R0DE NT1-A Microphone, Scarlet 212 Audio Interface (Revision 2), Windows 10 Pro X64 Retail, Bit Defender Total Security 2021, 2TB Seagate Expansion USB Hard Drive.
Third PC (Old Trustie) - Acer Aspire M3400, OEM Mainboard, AMD FX Athlon II X3 425 2.7Ghz, 16GB Corsair Value 1600Mhz Ram, OEM CPU Cooler, AMD R7 260 2GB GPU, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 2TB Samsung SATA III, 1 X OEM 16X DVDRW, 1 X Acer OEM Case, 1 X Corsair AF120 Case Can, Corsair CX500 Bronze+ CPU, Logitech MX Master Mouse, Corsair K30 Keyboard, Windows 10 Home X64 OEM, Logitech C920 Webcam, Bit Defender Total Security 2021.
Printers Include - Canon MG5750, Canon, IP8750,  Canon Pixma Mega tank G5050 & 2 X Samsung Xpress C410W.
1 X Zexrow Xbox360 Wired Game Controller.
TP Link Archer AX6000 Cable Router Wifi6 with a Virgin Media Hub 4.0 in Modem only mode running 1GB Fibre internet.
Samsung Galaxy S21+ 256GB Mobile Phone.
Internet Speed.....
https://www.speedtest.net/result/9935039193
https://linustechtips.com/topic/1098012-intel-cpu-cooling/#findComment-12840281
liquid is better in max cooling power, but air cooling can cool even the highest end SKU at stock speeds if not overclocked a bit more with careful voltage control
Desktop benching:
https://linustechtips.com/topic/1098012-intel-cpu-cooling/#findComment-12840339
Air cooling for me. Air cooling last longer and no leak or pump failure like AIO or custom water cooling. If we are talking about custom water cooling, then you are going to do a lot of researches for parts to fit in your case and style, and a lot of maintenance.
https://linustechtips.com/topic/1098012-intel-cpu-cooling/#findComment-12840343
Aesthetics play a big role in the choice for a lot of people with glass panels nowadays (especially at stock speeds, where any choice has fine options, basic air coolers or small AIOs work on most SKUs just check TDP).  The custom loops are awesome looking but more for hobbyists.  The benefit you get from it (in terms of value per dollar and time put in) is dismal at best, being that a D15 can keep up and takes about 5 minutes to install.  All that said, if you are looking at that kind of cooling, it really is more about the journey (the building process and aesthetic end result) that people enjoy, and it being kind of an art piece.  Not that there is anything wrong with that, they look sweet as hell.
Some people love the looks of an AIO but they aren't necessary currently.  Admittedly, they aren't a difficult install at all, nothing like a custom loop.  A good air cooler (D15, U12A, DRP4) can keep up with or beat almost any AIO, and if they can't that AIO probably costs as much as a decent CPU themselves (compare enermax 360 AIO and ryzen 3600 new price, puts things in perspective) and are going to be doing some intense OC on a hot CPU
TL;DR, air or liquid is fine, both will get the job done.  Check the TDP on the CPU you are looking at and match it with a cooler that can handle that spec and you will be fine!
El Zoido:  9900k + RTX 4090 / 32 gb 3600mHz RAM / z390 Aorus Master
The Box:  3900x + RTX 3080 /  32 gb 3000mHz RAM / B550 MSI mortar
https://linustechtips.com/topic/1098012-intel-cpu-cooling/#findComment-12840397
  • 2 weeks later...
Thanks all! I Appreciate it. Looks like the fan cooling should be the way to go here. I dont care about the "prettiness" aspect. :)
Since there has been so much investment in the industry for water cooling, maybe its time to invest in AC cooling for CPU's instead of just a fan cooling....
https://linustechtips.com/topic/1098012-intel-cpu-cooling/#findComment-12876457
There is a good video on that there is not a huge difference unless you go all out on either one. If you want simplicity then go for air if you want performance and style go for an aio. If you wanna go to the extreme get a custom water loop. At least this is how I break it down
https://linustechtips.com/topic/1098012-intel-cpu-cooling/#findComment-12878566
