dxr 1060
Go to solution Solved by Fasauceome,
Just now, Saksham said:
6gb laptop variant.
The laptop variants are the same as desktop variants so you're good to go.
The 1060 6GB is supported by Nvidia for DXR, what 1060 are you referring to?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1097866-dxr-1060/#findComment-12839124
6gb laptop variant.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1097866-dxr-1060/#findComment-12839136
Speed out of equation, it is supported. Useful for taking screenshots.
Desktop benching:
https://linustechtips.com/topic/1097866-dxr-1060/#findComment-12839150
