I tried to update via internet the X570 motherboard, after the update and pressing ok, the computer restarted and the "BIos Update Led Firmware" message has showed up. Then I disassembled the computer box and tried to take off the batteries and put them again. After turning on the computer the same issue remained.
https://linustechtips.com/topic/1096699-bios-update-led-firmware/
Just wait, it'll finish, reboot and start normally.
Ftr when your computer says "Do no restart or shut down" it's generally a good idea to listen, you better hope you didn't just kill the onboard RGB.
Main Rig:-
Server:-
The problem its never end the update , I left 1 day with the pc on and its still the same
  • 8 months later...
I ran into this issue yesterday. Note that the RGB lighting was frozen. After 45m it sent me to the BIOS screen and asked me to revert to previous changes. I tried that but I hadn't made any changes. I saved and exited then it booted Windows. I entered Armory Crate and updated everything. I restarted my system to complete the updates and it happened again. So, I shut down my computer and turned off the power supply. I walked away to let all the capacitors die and lights to shut off. I turned on the power supply and booted up the system with no issues. I've booted a few times since them and it's running okay but the RGB lighting still needs to be restarted sometimes. I hope this helps you or anyone else that that encounters this issue.
I like to play games and eat cookies.
I also build and sell gaming computers.
