Static fan comparison on a Air cooler help.
Solved by Eumel2,
Tldr: The cooling power is based on the fin area and not so much on the airflow given you get enough of it.
Heat transfer is based on temperature difference, so the maximum you can achieve is (fin temps)-(ambient temp) and it gets reduce the more already warmed up air passes over the fins (fin temps)-(air temp). When you get enough airflow the air temp is only gonna rise a couple degrees over ambient so the temperature difference will change only by a few percent as in 80°C-20°C to 80°C-23°C. That means that enough airflow to keep the air temperature in the cooler sufficently low will barely profit from more airflow.
