Hello!
When I finished by new build, I gave my old PC away to a friend. This machine is old, but it still runs the games she wants to play just fine. If it helps, heres the specs:
M5A97 R2.0 Asus Motherboard
AMD Phenom II X4 processor
16GB G.Skill Ripjaws X Memory 1600mhz
Zotac GTX 1050 OC (powered through PCI slot) - formerly a GTX 760.
She has had an issue with no display coming up on screen. When I say no display, I dont even think the monitor wakes up from sleep when the computer is powered on. She and her boyfriend suspected it was a graphics card (Ye Olde 760), so they went and bought a low range card (Ye Cheape 1050). The concern still persists after card replacement. I am not too sure where to go from there, other than say that the old components have finally lived their lifespan (mobo, cpu, etc)
I am curious if anyone has any other ideas? I have an extra board, chip and RAM I can throw in to that computer without spending a dime, I just want to know what troubleshooting should be done first before I pull that trigger.
CPU: Ryzen 7 5800X GPU: Sapphire Pulse RX 9070XT Motherboard: Asus ROG Strix X470-F RAM: Corsair 32GB Vengeance 3600Mhz PSU: Corsair RM850X White
Cooling: Corsair H115i RGB Storage: Samsung 970 Evo NVME (2TB) Case: NZXT H500i White
Keyboard: Corsair K70 Mechanical Mouse: Logitech Superlight 2
https://linustechtips.com/topic/1096186-old-pc-need-some-help-here/
you can use these to troubleshoot before donating them.
Primary PC:
PSU tier list
How many watts do I need?
Also try a DDU of the drivers and reinstall through Geforce Experience.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
Also try another video cable, just a thought....
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
We have tried a new video cable, HDMI, DVI on the 760, and DisplayPort on the new card. no dice.
I cannot do anything of a driver check or re-install if I plain and simply have no display whatsoever
I would say its time to retire the PC.  Or think it is the motherboard and wasting money on that and still no go.  Something is off I'm stumped.
Just out of curiosity,how often does it happen?
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
100% of the time, my man.
since OP said there was no video output, but I wonder if that extends to the BIOS
If it was living up to expectations it is worth an attempted fix at least
Primary PC:
PSU tier list
Well thats the thing. If its Mobo/CPU related, I have replacement parts sitting in a box ready to install. But before I go dissecting this machine, I want to be sure what I am removing will solve the problem.
Part of the steps to diagnose what is wrong would be to replace/reseat parts. If it is not posting at all or displaying anything but is still powered on it could be a ram issue, try reseating or replacing the ram and see if that works, if it still doesn't post after being reseated or with the other ram then it could be the CPU or Motherboard. Another thing, was the Monitor they are trying to use the one you had originally used with the PC or one they had already or bought separately, maybe test another device with HDMI on the monitor just to rule out it isn't the monitor itself. Or hook the PC up to a different monitor or TV and see if it works on there.
So she has tried 3 different displays. Her own, her roommates and also the living room TV. She has also tested the concern with other HDMI, DVI and DisplayPort cables. No dice.
I know this motherboard has a MEMOK! light that illuminates for about a second and goes out. Typically if it was a memory problem (for incompatible RAM at least), it would stay solid and you would have no POST. But that could be a different story for malfunctioning RAM. When the 760 was still installed, I asked her to confirm that there are 2 green lights illuminating on the card, which was affirmative, as well as the green light just below the card on the motherboard.
I'd like to add a note to the forum here, see if anyone can give me some feedback.
I am going over there tomorrow with replacement parts and tools, in case I happen to need them. I have this little speaker that I can plug into the motherboard, hopefully I can get some beep codes. That being said, I hear that there are other manufacturers that develop the BIOS for Asus. Can anyone tell me who manufactures the BIOS for the M5A97 R2.0?
I plan on doing a couple things, first off ensuring the GPU is fully seated, as well as ram, drives, etc. I was advised by Asus Support to try clearing the CMOS as well as removing the ram and seeing if it will POST with one stick of RAM in one slot.
If no bueno, at least I have some replacement parts for her.
