I am from: Philippines
My budget is: ₱60,000($1,145.19)
Am I building now?: Not yet, I plan to build it in first week of September.
My build is for: I plan to play mostly mmorpg games and also things like witcher 3 down the road.
I want to game at: 1920x1080 at 144hz
Do I need a monitor?: yes
Do I need peripherals?: no
Situational notes: I will be both buying locally and in US via a freight services.
https://linustechtips.com/topic/1096108-first-pc-build/
Pricing in the Philippines is a beast all its own, a friend of mine was telling me about the huge import taxes on electronics, like 50%. Also, last I recall the i7 7700k was somehow a reasonable price compared to something like the i5 8600k which would make for quite the 144 fps gaming PC.
for your budget, what are the prices available to you for:
i5 8600k
i7 7700k
Ryzen 5 3600
and motherboards to go with them:
Z370
Z270/170
B450
I think graphics cards make a little more sense, with availability of RX 580 and GTX 1060 6GB models being decent, though I wonder what new releases look like over there. How much would an RTX 2060 or RX 5700 run you?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1096108-first-pc-build/#findComment-12824673
R5 3600, GTX 1660 Ti and the cheapest 144Hz IPS display you can find should fit in the budget
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($197.75 @ OutletPC)
Motherboard: ASRock B450M Steel Legend Micro ATX AM4 Motherboard  ($89.98 @ OutletPC)
Memory: Crucial Ballistix Sport LT 16 GB (2 x 8 GB) DDR4-3200 Memory  ($69.99 @ Newegg)
Storage: Crucial BX500 240 GB 2.5" Solid State Drive  ($31.99 @ B&H)
Storage: Western Digital Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive  ($41.99 @ Newegg)
Video Card: EVGA GeForce GTX 1660 Ti 6 GB XC ULTRA GAMING Video Card  ($269.99 @ Newegg)
Case: Cooler Master MasterBox Lite 5 ATX Mid Tower Case  ($39.99 @ Newegg)
Power Supply: Corsair CX (2017) 550 W 80+ Bronze Certified ATX Power Supply  ($68.99 @ Amazon)
Monitor: LG 27GL650F-B 27.0" 1920x1080 144 Hz Monitor  ($279.99 @ Amazon)
Total: $1090.66
Generated by PCPartPicker 2019-08-20 13:47 EDT-0400
https://linustechtips.com/topic/1096108-first-pc-build/#findComment-12824708
Total: $1090.66
Prices of PC parts are way off in Philippines. No point in making a random list. You'll have to link the parts in the online stores that are available in Philippines.
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1096108-first-pc-build/#findComment-12824717
i5 8600k
i7 7700k
Ryzen 5 3600
Z370
Z270/170
B450
the i5 8600k the lowest I see is 10000($190.84)
i7 7700k is 9999($190.83)
and Ryzen 5 3600 is 10900($207.98)
an RTX 2060 would be $276.67 and RX 5700 is 360.62
I can also order in US and just ship it with a freight services I know that offers it to save money.
https://linustechtips.com/topic/1096108-first-pc-build/#findComment-12824838
Total: $1090.66
Thank you for this but do you think we could downgrade the monitor to atleast 24 inches and up my video card?
https://linustechtips.com/topic/1096108-first-pc-build/#findComment-12824840
That makes the 8600K the best buy, unless Z170 and Z270 boards are super cheap. There's also the i7 8700 if you could potentially get a good deal and then you could get a cheaper B360 motherboard. Slap some DDR4 3000 in there and it would go really well.
The rtx 2060 would be my choice then.
So what about PSU and SSD prices?
Primary PC:
PSU tier list
https://linustechtips.com/topic/1096108-first-pc-build/#findComment-12824863
5 minutes ago, sgian83 said:
what kind of psu and ssd you are looking for so I can search its price
Well usually the Corsair CX is pretty cheap what units could you get
Primary PC:
PSU tier list
https://linustechtips.com/topic/1096108-first-pc-build/#findComment-12826198
47 minutes ago, sgian83 said:
I could get cx550m for $73.63 is it a good deal?
Well that's not much higher than USD pricing actually. What are some of the other units at that price range you've seen?
Primary PC:
PSU tier list
https://linustechtips.com/topic/1096108-first-pc-build/#findComment-12826253
cooler master mwe gold 550w - $85.88, I don't know what kind of psu I should be looking for can you give me a list of psu that is good so I could look up its prices btw you can use this site as preference for pricing in our country https://pinoypartpicker.com/buildapc/ and I can do it 65000 max
https://linustechtips.com/topic/1096108-first-pc-build/#findComment-12826261
I use the forum's tier list for my basis of comparison
tier B for the budget oriented is a good call
Primary PC:
PSU tier list
https://linustechtips.com/topic/1096108-first-pc-build/#findComment-12826270
I see thanks some of the psu is not available here, so I will just list what is available and its price in US
Cooler Master MWE Bronze 600W - $69.23
Cougar GXS 750 - $86.06
Evga 650 B3 - $88.35
SeaSonic M12II 750W - $94.66
Thermaltake Smart BX1 RGB 750W - $75.92
that's the only available psu according in pinoypartpicker
https://linustechtips.com/topic/1096108-first-pc-build/#findComment-12826299
Out of all of these, the Cougar GX-S should be your pick
Primary PC:
PSU tier list
https://linustechtips.com/topic/1096108-first-pc-build/#findComment-12827116
CPU: AMD Ryzen 5 2600X 3.6 GHz 6-Core Processor  ($145.89 @ OutletPC)
Motherboard: ASRock Fatal1ty B450 GAMING K4 ATX AM4 Motherboard  ($94.89 @ OutletPC)
Memory: Team T-FORCE VULCAN Z 16 GB (2 x 8 GB) DDR4-3200 Memory  ($62.99 @ Newegg)
Storage: Intel 660p Series 1.02 TB M.2-2280 NVME Solid State Drive  ($94.99 @ Amazon)
Video Card: ASRock Radeon RX 5700 8 GB Video Card  ($329.99 @ Newegg)
Case: Fractal Design Focus G ATX Mid Tower Case  ($44.99 @ Amazon)
Power Supply: In Win 600 W 80+ Gold Certified Semi-modular ATX Power Supply  ($60.00 @ Amazon)
Monitor: LG 27GK750F-B 27.0" 1920x1080 240 Hz Monitor  ($299.00 @ B&H)
Total: $1132.74
Generated by PCPartPicker 2019-08-21 10:26 EDT-0400
https://linustechtips.com/topic/1096108-first-pc-build/#findComment-12827156
