I've been out the cooling game for a while. I personally use the Kraken X62 for the aesthetics, but the cooling isn't nothing to write home about. (To be honest, the software NZXT use is kinda crap)
Noctua has a very good track record with their air coolers.
Be Quiet Dark Rock Pro has always been one of my personal favourites in terms of air cooling (looks pretty good too) and I think their recent V4 has a very easy mounting system. (Or at least easier compared to the V3)
Corsair gets a good rep from water cooling with their hydro series.
Point is, aesthetics is what I'd mainly focus on, you'll get about the same cooling +- 2C as long as you go reputable.
https://linustechtips.com/topic/1095537-ryzen-overclock-cooler/#findComment-12819606
22 minutes ago, Zihanouk said:
I'm don't want to go sub zero cus of the hassle.
Not that anyone even goes subzero at all for their everyday use OC, because you need a high powered chiller for that
What's the best proformance air cooler or AIO?
Got a budget?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1095537-ryzen-overclock-cooler/#findComment-12819629
4 minutes ago, Zihanouk said:
Under $220(US). So basically no.
hard to argue with either the dark rock pro 4 or NH-D15
Primary PC:
PSU tier list
https://linustechtips.com/topic/1095537-ryzen-overclock-cooler/#findComment-12819806
I am using a DarkRock 4 (not even pro) to cool my 2600 @ 4.1 Ghz OC.
Temps are never exceeding the 60°C mark in daily use(gaming+streaming). Only when i do benchmarks i might get to 65°C :D  ( Roomtemp. in summer 35+°C)
And my case is a 9 year old almost completely closed one with 1 fan in and 1 out. :'D
So i can recommend it haha. Doing a hell of a job.
https://linustechtips.com/topic/1095537-ryzen-overclock-cooler/#findComment-12821289
