Just now, drkknghtavngr said:
Why do i hear static noises/buzzing on my speakers/headphones when plugged in at the front jack and how do I fix this? Rear Jack works fine though.
There are a lot of factors in play here:
The quality of the port
The distance between the front port to the motherboard
The quality of the cable between the motherboard to the front port
There is more but those are the most likely to cause this.
It looks like it won't be an easy fix,
You can try to replace the port and the cable with better ones.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58
