1 minute ago, Slydemise said:
I am truly getting out of my zone when it comes to keyboards.
Could someone please inform me of all of the parts needed to build an ergonomic mechanical board.
lube
stabilizers
master/slave pcb
keycaps
switches
What solder? Use flux?
I appreciate any help!
Buy a cheapo one be cheaper probably
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
I agree with the above, designing and building a keyboard from the ground up is more trouble than it's worth, unless there's a valid reason. Ie money and time to burn.
Here's a short read if you want a kit Link
Pretty sure Linus did a vid about this too, might want to check it out.
Master/slave pcb, lol gigity
stabilizers
master/slave pcb
Since you mention an ergonomic keyboard, are you talking about a split keyboard? If you are, then you should check out https://keeb.io/ They have a lot of choices and most of the parts can be bought there except the switches and keycaps. If that is not what you meant, then please elaborate.
For the switches and keycaps, there are many affordable options to buy from. Aliexpress, bangood, etc.
For lube, you can get it from here: https://www.1upkeyboards.com/shop/parts-and-tools/lubricant/switch-lubricant-2ml/
Pretty much any solder that comes with a soldering kit would work.
If you have never soldered before, check out these tutorials:
For flux, just get a good reviewed one but in all honesty, you should be fine with just the solder since most solder has flux in it's core.
On 8/18/2019 at 3:59 PM, Slydemise said:
lube
This depends heavily on the switch you're using if you lube Gateron Clears with GPL206g2 the lube would be too thick and make the slider stick and not move if you use GPL105 on Cream switches they won't stay due to the pure pom housings and slider. But in general, I would recommend you to use 3203, which is a light-medium lube that can be used on most switches, it's lighter than 3204 and a bit more consistent.
stabilizers
Depends on the case and PCB, some keyboards use plate mount while others use PCB mount, the best stabs imo are modded GMK/Cherry screw in stabs. There are also many sizes of stabs, most boards use a few 2U stabs for the mods and a 6.25 or 7U spacebar stab.
master/slave pcb
Depends on the layout you want, whether you're using mx or alps. If you want underglow or smd leds built in, whether you want hotswap.
keycaps
Colourways and sculpt are heavily based on preference, but you should always try and get a set that has good compatibility that is made by a reputable manufacturer like GMK SP EPBT or JTK. Also some untraditional layouts such as grid boards require you to use unsculpted or blank caps.
switches
P R E F E R E N C E
Do you want something tactile? Linear? Silent or not? PCB or Plate mount? Does it need to support smd leds?
It looks like you don't quite know what you want, you should do some research to see what exact layout or case you want to use.
