fullmod = all the cables are detachable and come separate from the psu itself
semimod = only the essential cables are non detachable (24pin and some other stuff) , the rest come separate from the psu itself
nonmod = no cables are detachable , they all are preattached to the psu
https://linustechtips.com/topic/1095023-power-supply/#findComment-12815706
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1095023-power-supply/#findComment-12815708
Fully modular and semi-modular refers to the cables that come out of the PSU.
Non Modular, AKA "Fixed"
  • All cables are fixed to the power supply.
Semi Modular
  • Some cables are fixed to the power supply, some are removable. Typically Motherboard 24pin and CPU power connectors are fixed with the SATA, PCIe, and Molex connects removable.
Fully Modular
  • All cables are removable. Best if you are wanting to use custom sleeved cables for aesthetics.
https://linustechtips.com/topic/1095023-power-supply/#findComment-12815709
