Hello everyone. This is my first post on this forum, and im seeking help as I'm about to build my first PC. I am upgrading from an Alienware Aurora R7 (gtx 1070, i5 8400, 16gb ram) It was a decent pc, but very very hard to further upgrade. I decided to go ahead and sell it, and put it towards this one I'm building. Anyway, I'm from New Jersey, and my budget is $1500-1600ish. I need the PC for mainly streaming and gaming. I'll mostly be playing CSGO, Rainbow 6, and streaming Rust on it. I have a 240hz 1080p monitor, and 60hz 1080p monitor.
The parts I have chosen so far:
I am unsure about the case, so I'll take any recommendations. The PC will sit under my desk and the tempered glass side will probably be facing the wall so anything thats cheaper I'll take. I also found a great open box deal at a local microcenter for the 2070 for only $390, so I'm definitely going with the 2070 on this one. Anyway, I appreciate any suggestions
https://linustechtips.com/topic/1094762-first-build-need-help/
Quote and/or tag people using @ otherwise they don't get notified of your response!
The HUMBLE Computer:
AMD Ryzen 7 3700X • Noctua NH-U12A • ASUS STRIX X570-F • Corsair Vengeance LPX 32GB (2x16GB) DDR4 3200MHz CL16 • GIGABYTE Nvidia GTX1080 G1 • FRACTAL DESIGN Define C w/ blue Meshify C front • Corsair RM750x (2018) • OS: Kingston KC2000 1TB GAMES: Intel 660p 1TB DATA: Seagate Desktop 2TB • Acer Predator X34P 34" 3440x1440p 120 Hz IPS curved Ultrawide • Corsair STRAFE RGB Cherry MX Brown • Logitech G502 HERO / Logitech MX Master 3
Notebook:  HP Spectre x360 13" late 2018
Core i7 8550U • 16GB DDR3 RAM • 512GB NVMe SSD • 13" 1920x1080p 120 Hz IPS touchscreen • dual Thunderbolt 3
https://linustechtips.com/topic/1094762-first-build-need-help/#findComment-12813720
1 minute ago, builder1909 said:
Do i need the cooler? Won't the ryzen stock cooler be enough?
It will be fine if you don't plan to overclock, so feel free to skip it :) and you can always get it later.
https://linustechtips.com/topic/1094762-first-build-need-help/#findComment-12813742
I see. I don't plan on overclocking, but what about the 3700? Will it be good enough to stream games like Rust?
https://linustechtips.com/topic/1094762-first-build-need-help/#findComment-12813767
PCPartPicker Part List
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core Processor  ($499.00 @ B&H)
CPU Cooler: Scythe Mugen 5 Rev. B 51.17 CFM CPU Cooler  ($48.99 @ Amazon)
Motherboard: Asus TUF GAMING X570-PLUS ATX AM4 Motherboard  ($189.89 @ OutletPC)
Memory: G.Skill Trident Z RGB 16 GB (2 x 8 GB) DDR4-3600 Memory  ($99.99 @ Newegg)
Storage: Intel 660p Series 512 GB M.2-2280 NVME Solid State Drive  ($59.99 @ Amazon)
Storage: Seagate Barracuda 3 TB 3.5" 7200RPM Internal Hard Drive  ($79.89 @ OutletPC)
Video Card: MSI GeForce RTX 2070 8 GB ARMOR OCV1 Video Card  ($409.99 @ Newegg)
Case: Cooler Master MasterBox 5 ATX Mid Tower Case  ($69.99 @ Amazon)
Power Supply: EVGA SuperNOVA G1+ 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($85.88 @ OutletPC)
Total: $1543.61
Generated by PCPartPicker 2019-08-16 15:04 EDT-0400
https://linustechtips.com/topic/1094762-first-build-need-help/#findComment-12813817
Get a better one later, when you have new Money at hand. Why stress the CPU more than you have to?
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/1094762-first-build-need-help/#findComment-12814048
Motherboard: Asus TUF GAMING X570-PLUS (WI-FI) ATX AM4 Motherboard  ($195.99 @ SuperBiiz)
Memory: Team Vulcan 16 GB (2 x 8 GB) DDR4-3000 Memory  ($61.89 @ OutletPC)
Storage: Sabrent Rocket 512 GB M.2-2280 NVME Solid State Drive  ($59.98 @ Amazon)
Storage: Seagate Constellation CS ISE 3 TB 3.5" 7200RPM Internal Hard Drive  ($57.50 @ Amazon)
Video Card: NVIDIA GeForce RTX 2070 SUPER 8 GB Video Card  ($499.99 @ Best Buy)
Case: Fractal Design Meshify C ATX Mid Tower Case  ($83.99 @ Amazon)
Power Supply: EVGA SuperNOVA P2 650 W 80+ Platinum Certified Fully Modular ATX Power Supply  ($85.88 @ OutletPC)
Total: $1544.22
Generated by PCPartPicker 2019-08-16 22:40 EDT-0400
https://linustechtips.com/topic/1094762-first-build-need-help/#findComment-12814662
I'll recommend something like this instead...
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  ($329.00 @ B&H)
Motherboard: Asus PRIME X570-P ATX AM4 Motherboard  ($168.99 @ SuperBiiz)
Memory: OLOy WarHawk RGB 16 GB (2 x 8 GB) DDR4-3200 Memory  ($66.99 @ Newegg)
Storage: HP EX900 500 GB M.2-2280 NVME Solid State Drive  ($49.99 @ Amazon)
Storage: Hitachi Ultrastar 7K3000 3 TB 3.5" 7200RPM Internal Hard Drive  ($52.23 @ Amazon)
Video Card: EVGA GeForce RTX 2080 SUPER 8 GB BLACK GAMING Video Card  ($699.99 @ Amazon)
Total: $1537.06
Generated by PCPartPicker 2019-08-16 23:59 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1094762-first-build-need-help/#findComment-12814773
Total: $1537.06
I like this build. Think I'll go with this one
https://linustechtips.com/topic/1094762-first-build-need-help/#findComment-12815135
