Have you tried a different ethernet cable from your pc to the jack?
why no dark mode?
Current:
Watercooled Eluktronics THICC-17 (Clevo X170SM-G):
CPU: i9-10900k @ 4.9GHz all core
GPU: RTX 2080 Super (Max P 200W)
RAM: 32GB (4x8GB) @ 3200MTs
Storage: 1TB WD Blue NVMe SSD
Displays: Internal 1080p@300Hz, Asus ROG XG-17 1080p@240Hz (G-Sync), Gigabyte M32U 4k@144Hz (G-Sync), External Laptop panel (LTN173HT02) 1080p@120Hz
Asus ROG Flow Z13 (GZ301ZE):
CPU: i9-12900H @ Up to 5.0GHz all core
- dGPU: RTX 3050 Ti 4GB
- eGPU: Radeon 6850m XT XGm 16GB
RAM: 16GB (8x2GB) @ 5200MTs
Storage: 1TB NVMe SSD, 1TB MicroSD
Display: Internal 1200p@120Hz
Minisforum MS-A2:
CPU: Ryzen 9 9955HX
RAM: 63GB (2x32GB) DDR5 @ 5600MTs
Storage: 2x 1TB Various NVMe SSD in RAID 1, 4x 10TB HGST Enterprise HDD in RAID Z1
https://linustechtips.com/topic/1093691-ethernet-not-working/#findComment-12804926
Just now, Dell Dorado said:
yes i have tried multiple.
do you know where the jack under your desk goes to?
why no dark mode?
Current:
Minisforum MS-A2:
CPU: Ryzen 9 9955HX
https://linustechtips.com/topic/1093691-ethernet-not-working/#findComment-12804932
yes it goes to the router
Did you try plugging something directly into that port on the router?
why no dark mode?
Current:
Minisforum MS-A2:
CPU: Ryzen 9 9955HX
https://linustechtips.com/topic/1093691-ethernet-not-working/#findComment-12804937
2 minutes ago, Dell Dorado said:
no i havent
I would test it, if it works then the cable in the wall/where it connects to the jacks on either end are bad. You might have to take the jack off and re-terminate the cable.
Edited by Mnky313
typo
why no dark mode?
Current:
Minisforum MS-A2:
CPU: Ryzen 9 9955HX
https://linustechtips.com/topic/1093691-ethernet-not-working/#findComment-12804944
If Windows 10
Start Menu -> Settings -> Network/Internet -> Network Reset -> Reset Now -> Reboot when prompted.
PLEASE QUOTE ME IF YOU ARE REPLYING TO ME
Desktop Build: Ryzen 7 2700X @ 4.0GHz, AsRock Fatal1ty X370 Professional Gaming, 48GB Corsair DDR4 @ 3000MHz, RX5700 XT 8GB Sapphire Nitro+, Benq XL2730 1440p 144Hz FS
42U Server Rack: ISP Modem + UDM-SE + APC 3kVA UPS + 3x Dell Precision 5820 + TBD
Retro Build: Intel Pentium III @ 500 MHz, Dell Optiplex G1 Full AT Tower, 768MB SDRAM @ 133MHz, Integrated Graphics, Generic 1024x768 60Hz Monitor
https://linustechtips.com/topic/1093691-ethernet-not-working/#findComment-12804961
give me instructions for a technological noob please
https://linustechtips.com/topic/1093691-ethernet-not-working/#findComment-12804962
for terminating a cable into a jack you "need" (it can be done without one, but it's not recommended) a certain tool, I would follow a tutorial like this
But if @rcmaehl's instruction works then it wasn't a hardware issue. You should also try another PC/laptop before doing anything with the jacks.
why no dark mode?
Current:
Minisforum MS-A2:
CPU: Ryzen 9 9955HX
https://linustechtips.com/topic/1093691-ethernet-not-working/#findComment-12804986
i dont think it was a hardware issue because people i have another router and i can connect that through ethernet
https://linustechtips.com/topic/1093691-ethernet-not-working/#findComment-12804992
