My pc will auto shut down once my processor hit around 70 degree celcius, is there any way I can fix or disable this? I heard about I can change the max processor temp before the pc shut down but I couldn't find it in the bios
My specs:
Mobo: asrock n68c-gs4 fx (bios version 1.3)
Processor: AMD FX-8320
RAM: 8gb ddr3 1600mhz
GPU: GTX 750ti
CPU cooler: Cooler Master Hyper H411R
https://linustechtips.com/topic/1093537-pc-auto-shutdown-without-warning/
My specs:
GPU: GTX 750ti
Mhh looking into google the max temp of your chip is 70 but it should slow down and only shut down at 80 (newer chips go way hotter) older amds are very strange in terms of temps.
What kind cooler are u using ? There is always a reason for high temps repaste the cpu clean the cooler etc making the temp limit higer does not fix ur temp prob oh i am sry i see what cooler ur using now my bad ^^ did u already repaste/clean it
1 minute ago, xhackforeverxdx said:
Mhh looking into google the max temp of your chip is 70 but it should slow down and only shut down at 80 (newer chips go way hotter) older amds are very strange temp in terms of temps.
What kind cooler are u using ? There is always a reason for high temps repaste the cpu clean the cooler etc making the temp limit higer does not fix ur temp prob oh i am sry i see what color ur using now my bad ^^ did u already repaste/clean it
I had repaste it and cleaned my pc yesterday but the problem is still there
You're lucky it even works on that motherboard. The VRM-s are probably overheating.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
3 minutes ago, yozora01x said:
I am not sure which reading you are talking about
I am talking about the core voltage aka v core but 1.32v is pretty normal for that chip u could try to undervolt it and see if it stays stable at like 1.25 v core that would lower the temps a bit but i am still not sure why the chip is even overheating
May I ask how should I do the undervolt?
4 hours ago, xhackforeverxdx said:
Could overheatings vrms leak voltage so the cpu overheats ? Could be possible or
Highly unlikely. But it would cause CPu throttling, cooler missbehaving and shutdowns.
Could be your PSU, I had a psu that had its fan unplugged (The guy I got it off must have done this), My pc started shutting down randomly but I didnt think much of it, untill one day. it shutdown, I clicked the power button *BANG* a blue flame and smoke...  it had melted one of the capacitors, had to get a new PSU.
Edit: nvm didnt read it properly, its when your cpu hits 70*c silly me
My specs:
GPU: GTX 750ti
It's thermal shutdown from an over heating CPU... had it happen a few times on my mums FX6300 when it was in a small case with poor airflow when ever the ambient temps rose (during the summer).
I switched the system out to a larger case with more fans, a larger cooler and it never gets above 60ºC now, even when stress tested.
So clean out the case, improve airflow and/or fit a better cooler as new thermal paste didn't work.
System 1: Gigabyte Aorus B450 Pro, Ryzen 5 2600X, 32GB Corsair Vengeance 3200mhz, Sapphire 5700XT, 250GB NVME WD Black, 2x Crucial MX5001TB, 2x Seagate 3TB, H115i AIO, Sharkoon BW9000 case with corsair ML fans, EVGA G2 Gold 650W Modular PSU, liteon bluray/dvd/rw.. NO RGB aside from MB and AIO pump. Triple 27" Monitor setup (1x 144hz, 2x 75hz, all freesync/freesync 2)
System 2: Asus M5 MB, AMD FX8350, 16GB DDR3, Sapphire RX580, 30TB of storage, 250GB SSD, Silverstone HTPC chassis, Corsair 550W Modular PSU, Noctua cooler, liteon bluray/dvd/rw, 4K HDR display (Samsung TV)
System 3 & 4: nVidia shield TV (2017 & 2019) Pro with extra 128GB samsung flash drives.
Your motherboard is rated for a max of a 95W CPU. The 8320 has a TDP of 125W. That CPU is not even on the QVL for that board. So the solution to your problem is a better motherboard with better VRMs, and a QVL which includes the 8320. Not to mention that your CPU cooler is only good for 100 watts. You'll need a better CPU cooler as well.
A better motherboard and a better cooler ...
Take an index finger, put it under the nose, take a deep breath AND get yourself a new platform.
5 hours ago, yozora01x said:
I had done repasting which helps my processor to cool down more but I realized my windows still shut down even though the temperature is around 56~63c
Let me repeate myself: Your motherboard is rated for a max of a 95W CPU. The 8320 has a TDP of 125W. That CPU is not even on the QVL for that board. So the solution to your problem is a better motherboard with better VRMs, and a QVL which includes the 8320. Not to mention that your CPU cooler is only good for 100 watts. You'll need a better CPU cooler as well.
Or, disable 2 cores in BIOS?
Primary PC:
PSU tier list
How many watts do I need?
I suppose thats one way of doing it. But Ive never done it myself. It would still be better to use a motherboard with the proper rating, and better vrms.
