Recently, I've been experiencing a lot of issues which I've experienced it before but this time it's even worst. Does anyone know why does my PC shuts down by itself when I'm browsing the website as well as playing games. Sometimes it gets stuck at Blue Screen of Death and doesn't restart after the scanning. Sometimes after scanning for errors, my PC won't restart by itself but I have to force shutdown. Anyone helpful tips will be appreciated. Thank you.
https://linustechtips.com/topic/1092696-need-help/
put memtest on a usb stick and test your ram: https://www.memtest.org/#downiso
make sure the ram is configured at proper voltage and latencies... if you get errors during memtest, maybe lower the frequencies a notch and retest
make sure your cpu cooler is properly installed and cpu is cooled
if you still have issues, maybe the power supply is failing ... what psu do you have,,,
https://linustechtips.com/topic/1092696-need-help/#findComment-12797297
When it goes off, is it connected to the power supply? if it is not connected to the power supply it's the battery.
If the battery does not work properly, it makes errors with the logs
https://linustechtips.com/topic/1092696-need-help/#findComment-12799085
