Psu buzzing sound
Go to solution Solved by BigDamn,
Is it under load or all the time? if it's under load it's not that unusual, however, I've run a 290x on an RM series PSU and didn't have any buzzing. If the 290x can't do it nothing can...
If it happens all the time that's certainly an issue. Record a video and send it to Corsair support and see what they think. They'll likely replace it for you.
QUOTE ME IF YOU WANT A REPLY!
PC #1
Ryzen 7 3700x@4.4ghz (All core) | MSI X470 Gaming Pro Carbon | Crucial Ballistix 2x16gb (OC 3600mhz)
MSI GTX 1080 8gb | SoundBlaster ZXR | Corsair HX850
Samsung 960 256gb | Samsung 860 1gb | Samsung 850 500gb
HGST 4tb, HGST 2tb | Seagate 2tb | Seagate 2tb
Custom CPU/GPU water loop
PC #2
Ryzen 7 1700@3.8ghz (All core) | Aorus AX370 Gaming K5 | Vengeance LED 3200mhz 2x8gb
Sapphire R9 290x 4gb | Asus Xonar DS | Corsair RM650
Samsung 850 128gb | Intel 240gb | Seagate 2tb
Corsair H80iGT AIO
Laptop
Core i7 6700HQ | Samsung 2400mhz 2x8gb DDR4
GTX 1060M 3gb | FiiO E10k DAC
Samsung 950 256gb | Sandisk Ultra 2tb SSD
https://linustechtips.com/topic/1092283-psu-buzzing-sound/#findComment-12794327
Okay thx guys!
I will check what I can do about it. And yes, it is making that noise even when the pc is off.
https://linustechtips.com/topic/1092283-psu-buzzing-sound/#findComment-12796433
2 hours ago, minordinor said:
Okay thx guys!
Yikes. Definitely want to get that replaced than
PC #1
PC #2
Corsair H80iGT AIO
Laptop
https://linustechtips.com/topic/1092283-psu-buzzing-sound/#findComment-12796822
