Static in headphones help!!
Solved by Crunken,
On 8/8/2019 at 8:25 PM, LogicalDrm said:But seems like you have bad integrated audio chip in there
On 8/8/2019 at 8:28 PM, Turtle Rig said:You took the words right out of my mouth LogicaDrm my friend.
When i started this post i just built the new PC and really didn't want to switch motherboard, but i did it anyway since no drivers or anything else worked. So i switched to an Asus Z390-F board and now it works fine, so you guys were right. Thanks :D
