Stock cooler's the cheapest, Deepcool gammaxx 400 is also cheap. Hate Hyper 212 Evo's scissor mounting frame, not sure if 212 Black and Arctic Freezer 33 or 34 are within budget or not.
Desktop benching:
What case and ram are you using?
1 hour ago, Silent_arrow said:
coorsair 200r and hyperx fury
As mentioned, the Gammaxx 400 works: https://pcpartpicker.com/product/w3c48d/deepcool-gammaxx-400-blue-7434-cfm-cpu-cooler-deepcool-gammaxx-400-blue
If you don't mind spending a bit more, the Neptwin V2 is better: https://pcpartpicker.com/product/3XXfrH/deepcool-cpu-cooler-neptwinv20
For lower noise, the Macho Direct isn't much more than the Neptwin V2: https://pcpartpicker.com/product/TsL7YJ/thermalright-cpu-cooler-machodirect
Make sure to quote a post or tag a member when replying or else they won't get a notification that you replied to them.
