Hyper X cloud 2 no sound out of right ear
Solved by Spuriae,
It's almost 100% the cable if fidgeting with it made it work again. The "easiest" repair is most likely to remove the current cable and route a new one through the cable opening, soldering the wires to the appropriate pads as described in this mod.
If you have the parts you may instead want to attempt a removable cable mod to prevent this sort of failure from happening again.
Featured Topics
RevGAM ·
Posted in Custom Loop and Exotic Cooling2 -
JakubR88 ·
Posted in Power Supplies6 -
1
2
4
4
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
