Hello,I have a geforce 940mx and i can push memory clock to 265 MHz, i used nvidia inspector (guru3D.covm). I increased the voltage by 37.5mV. when i ran benchmark and I used sensor monitoring and i found out the graphics is at power limit. Nvidia inspector doesn't have power limit setting. So i used msi afterburner and there I unlocked the voltage and i used the same clocks as nvidia inspector. But I can't unlock the power limit. So I´m asking you how to unlock power limit.
https://linustechtips.com/topic/1090724-power-limit-on-notebook/
U just cant its locked u could maybe use a costum bios but its not worth it
If it doesn't change then that means its locked, it makes sense because after all it is a notebook.
Edited by LinusTechTipsFanFromDarlo
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
NVIDIA has power limit locked down quite well.
I very much doubt you will find BIOS for 940mx that will allow you to go past the power limit.
You will have to do some soldering to modify the HW to unlock it or shorten the shunt resistors with a liquid metal.
Either way, its not worth it at all for this kind of graphics card. You will see barely any improvement in performance but you will see drastically lower battery life.
