I Built a 9900K System around 2 week ago and Stock Temps were at 89c in RealBench, I have Replaced the Paste with Arctic MX4 and that drop the temps by 2c.
I have Undervolted the CPU
    Multi Core Enhancement Disbaled
    XMP Enable
    Vcore Normal
    Adaptive -0.060
    LLC Auto
Hardware Info Reports Vcore is 1.200 with OCCT Large Data Set Running and 1.188v when playing Battlefield V
Hardware Inside my NZXT Phantom 630
  • Motherboard: Aours Master Z390
  • CPU: 9900K
  • AIO: H150I
  • GPU: Asus 2080Ti OC
  • RAM: 3000Mhz Platinum
Air Flow Layout
 Intake
          200mm Front 750RPM
          140mm Bottom 1000RPM
Exhaust
          140mm Rear 750RPM
          360mm H150I Top Performance Mode
15Min Pass of Real Bench + Ambient is around 20 c
https://linustechtips.com/topic/1090140-9900k-system-temps/
27 minutes ago, Metallus97 said:
Thats a little high for undervaluing, but it's ok. I think a D15 or something would outperform the AIO
I was honestly thinking about getting an Air Cooler, I have seen some benchmarks and it does better that the H150I at stock and OC
I am also thinking of getting a new case and setting the AIO up as an Intake, Just worried it will be a waste of time and money
https://linustechtips.com/topic/1090140-9900k-system-temps/#findComment-12777015
The only i9 9900k rig in my house has idles temps in the low 30s and games in the 70s on a Noctua NH-D15 with one fan. It has an all core 5ghz overclock at I think 1.25v.
The case is a SilverStone Technology RL06BR-GP and is the reason one fan on the Noctua NH-D15 is used. A be quiet! 250W TDP Dark Rock Pro 4 was pushed for the setup but the RGB ram was too tall.
The only case I would buy now is the Cooler Master MasterCase H500P Mesh. I don't like the styling but it is the only case that has enough air flow and width for an all air cooled overclocking setup using a Noctua NH-D15.
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
https://linustechtips.com/topic/1090140-9900k-system-temps/#findComment-12777180
1 minute ago, Matthew-g said:
@Metallus97 & @jones177
I am wondering, am I getting Insane Temps due to having the 2nd 8 Pin EPS connector in?
No, this only affects how much the CPU COLUD draw and not how much it actually does. For most uses it is not needed
FOLDING MONTH 2021! GOGOGO and save on some heating costs 🙂
https://linustechtips.com/topic/1090140-9900k-system-temps/#findComment-12777307
