My ram speed is lower than what it should be. I purchased a 3000mhz kit from corsair and its running at 2193mhz. Any way to fix this issue? Also my cpu temp for when its idle its bewteen 40c and 55c, is this normal?
Pc specs
ryzen 3700x (stock cooler)
msi b350 gaming pro (micro atx)
corsair vengeance lpx 8x2 gb 3000mhz
Gtx 1660 (pny)
CX 850M PSU
https://linustechtips.com/topic/1089892-ram-speed-and-cpu-temp/
idle its around 40-55. remind that the cpu constantly drawing watt from outlet.
Perhaps that is ram speed that is utilized?
  Spec: Macbook Air 2017
ProcessorPU: ii5 (I5-5350U |
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
 | GPU: Intel HD 6000 |
| Audio: JBL 450BT Wireless Headset |
https://linustechtips.com/topic/1089892-ram-speed-and-cpu-temp/#findComment-12774928
I have no idea re AMD, its been many years since I used AMD but re ram and intel platform the ram you have is probably running at stock ands you may need to increase the ram voltage in bios, I have G.Skills TridentZ purchased as 3600Mhz but at stock bios voltage (1.2v) its runs at 21945778028_RamVoltagespeed.JPG.9be7c69eceb57ea9946706882a6c3405.JPG133, when I push the voltage to (1.36v) I get the 3
16GB Kit (2 x 8GB)
Tested Latency 15-17-17-35
Tested Voltage 1.35V
Tested Speed 3000MHz
SPD Latency 15-15-15-36
SPD Speed 2133MHz
SPD Voltage 1.2V
Speed Rating
PC4-24000 (3000MHz)
Compatibility Intel 100 Series,Intel 200 Series,Intel 300 Series,Intel X299
https://linustechtips.com/topic/1089892-ram-speed-and-cpu-temp/#findComment-12774944
